Old 11-07-2006, 12:02 PM
thatotherguy186's Avatar
thatotherguy186 thatotherguy186 is offline
Send a message via AIM to thatotherguy186
Unhappy Transmission for 94 GA
Can anyone give me about the price for a Re-built Trans and Differential for a 94 grand am SE
Old 11-07-2006, 01:11 PM
troy1 troy1 is offline
AF -Advisor
Re: Transmission for 94 GA
well we need a few things before we can get you a estimate. is it a 3spd or 4spd auto? or is it a 5spd manual? The diff will be included in the rebuild sense its inside the trans. If your diff is busted up they will charge you for a core.
Old 11-07-2006, 03:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome on your first post on AF.
As said above.
Need more info.
And are you sure you need one?
Like what is it doing or not doing?
Or
Your local dealer or a good repair shop will give you a quote.
Tips on getting a good answer to your questions.
People trying to answer your question do not have a crystal ball.
So give them all of the info you have like year make and model and engine and transmission and mileage.
Also cars engine and transmission service history or any recent repairs or problems.
Also a description of your problem and what it is doing or not doing.
If you have codes give up the code no.
And remember a code does not say replace the part but only points to the problem that you have to check out.
So to better help you give up all of the info you have on it.
MT
Old 11-07-2006, 11:12 PM
it's a 4 spd auto and one of the gears shot out of the housing i have the pieces and there is trans fluid on the driveway
The left are the housing pieces and after looking at them they are aluminum so yea and the right are obviously the gear
Last edited by thatotherguy186; 11-07-2006 at 11:27 PM. Reason: added picture of pieces
Old 11-08-2006, 07:57 AM
MT-2500's Avatar
AF - Advisor
That does not sound good.
Time for a rebuilt or good used one.
Prices can range from a 2 hundered to 2K
I would shop around and check round.
Good Luck
MT
MT
Old 11-08-2006, 10:41 AM
alrighty thank you when i get it out i'll take some pictures for ya
Old 11-08-2006, 10:08 PM
AF -Advisor
well if you just blew up the diff and didn't bust the trans case or hurt the final drive ring gear you can just get a new diff and extention housing cover and get back on the road. Oh and no more peg-leg burnouts!!
Old 11-08-2006, 11:40 PM
Old 11-08-2006, 11:41 PM
Old 11-08-2006, 11:42 PM
theres the damage done!
Old 11-09-2006, 08:59 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Your picks arent showing up thatotherguy186.
Need to load them to a pic host such as photobucket.com or imageshack.com.
Then post the link or use the "insert image" button on the top of the quick reply box.
1999 Grand Am SS 3.4 OHV
Old 11-09-2006, 11:30 AM
Old 11-09-2006, 11:31 AM
Old 11-09-2006, 02:13 PM
Yip , Its broke !
Think you are going to need some repairs !
Were you doing neutral drops when this happened ??
