Old 11-07-2006, 11:10 AM
Bobm72059 Bobm72059 is offline
Exclamation 96 Cherookee SE 2 dr 5 speed manual
I am leaking clutch fluid. It looks like it is coming from behind the resivor under the hood. Is there a gasket I can replace behind it? How should the clutch pedal feel. Tight with little play or like mine soft with alot of play. Sometimes it is very hard to get it into reverse. Is there a clutch adjustment to tighten it up. Can anyone help.
Bob M
Old 11-07-2006, 11:56 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: 96 Cherookee SE 2 dr 5 speed manual
Sounds like the clutch master needs to be rebuilt or replaced. Depends on cost and where you live. Easy job though.
Edit: DC manual says parts replace only (no rebuild).
Old 11-07-2006, 02:19 PM
Question Re: 96 Cherookee SE 2 dr 5 speed manual
Do you mean the clutch solinoid where I keep filling it up with fluid?
Bob
Old 11-07-2006, 02:28 PM
AlohaBra's Avatar
The name for it is clutch master cylinder. And the name for the part that gets activated is called the clutch slave cylinder.
Part at Kragen's:
http://www.partsamerica.com/ProductL...aster+Cylinder
One hour or so labor (shop)...about $150 in California (plus cost of part).
Most home mechanics can do it in about .5 hour plus cleanup and bleed time.
Old 11-07-2006, 02:37 PM
Thanks. will that tighten up my clutch pedal as well.
Bob
Old 11-07-2006, 04:40 PM
AlohaBra's Avatar
Hydraulic clutch linkage is like hydraulic brakes, if it leaks the pedal will get spongy and not have as much travel. The whole principle of hydraulics is that liquids don't compress.
Old 11-15-2006, 03:50 PM
Replaced the clutch master cylinder and we are good to go. Thanks.
Bob
