Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-06-2006, 11:02 PM
nigelstubbblefield nigelstubbblefield is offline
Replacing Radiator
Replacing the radiator on a 95 Rodeo. It has a manual transmission. What is the cannister located next to the radiator and how to disconnect the radiator. Any other hints for removing and replacing appreciated.
Old 11-07-2006, 12:17 PM
surferfletch surferfletch is offline
Re: Replacing Radiator
I remember this being a very easy job on my '97. Disconnect the hoses. Remove the fan shroud. I had to disconnect ATF cooler lines, which you won't have to worry about. Two bolts/brackets hold the rad in place. Lift the old one out, slide the new one in. I'm not sure what cannister you are talking about. Which engine do you have? Again, this was on my '97 and I don't have my manual here to look at the possible differences. Good luck! Curious to know which radiator you'll be switching to.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 11-07-2006, 05:34 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Dont know if its the same on the '95 as on my '99 but on mine the reciever for the a/c is next to the condensing coil, which it sounds to me like that is what stubblefield is looking at. You dont want to mess with it.
The radiator would be on the engine side of the rad support, the condensing coil would be in front of it. You dont need to mess with the condensing coil or reciever to change out the radiator.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 11-07-2006, 06:20 PM
trooperbc's Avatar
trooperbc trooperbc is offline
and the condensing coil looks like a small radiator...right gizmo, aka the hvac guy ?
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 11-07-2006, 11:37 PM
Thanks for the advice. My son got the radiator out as suggested above. He bought the radiator at Schucks because he wanted it right away. It was a one size fits all and had capped tubes for connections to the AT cooling which caused a little confusion. The device next to the radiator is the AC condenser, one of the tubes appeared to go into the radiator.
Old 11-08-2006, 01:52 AM
Gizmo42's Avatar
Exactly, thats why I wanted to make sure he didnt start removing the wrong parts.
--Dave
Rear No-Slip Locker
Old 11-08-2006, 04:16 PM
Originally Posted by nigelstubbblefield
... and had capped tubes for connections to the AT cooling which caused a little confusion.
Ran into that with my first radiator swap in my Jeep a couple years ago. Just left them capped. Glad you got it done. Saved some money!
