Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 11-06-2006, 06:56 PM
hallboy hallboy is offline
Question Lower strut brace install
What's up. I have a friend with a 97 civic. He bought a 4 pack of braces. 2 tower strut bars and two lower bars. I know where the go but I'm not sure about the install.
Do you need to do anything special before pulling the bolt out that hold the lower arms inplace? They look to have tension on them. For the new braces it looks like you just pull two bolts out, place the brace and put the bolts back out. I'm not sure if you need to jack up the car or brace the arms first or what. I don't have much experience with the underside.
Thanks fro the help.
Hallboy
Old 11-06-2006, 07:59 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Lower strut brace install
Do the uppers with the car on the ground. Do the lowers with the car off the ground.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-08-2006, 07:07 AM
That's what I was thinking. If I lift the car from the frame will it be safe to remove the bolts that hold the 2 arms in place?
Old 11-08-2006, 08:49 PM
NA is Best!
Yeah, use the reenforced lift points along the edge of the underside of the car.
