Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-06-2006, 04:25 PM
morgantj13 morgantj13 is offline
Problem with brakes in 1989 88
Hey, Ive got a problem with my brakes. When I first got the car a couple weeks ago, the brakes were fine, would be firm until the car stopped. But the last two days whenever I apply the brakes, it gets about 2/3's down and then I hear a clunk and the pedal jiggles. The brakes work fine(I can still stop fast if I want)but every couple brakes the brake pedal does the thing where I will be applying pressure and then it makes a clunk....
Old 11-07-2006, 12:19 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Problem with brakes in 1989 88
What do you mean by the pedal jiggles? Does it go from firm to really hard to frim to hard again? Or does it vibrate? Or ?
What color is your fluid? It should be a nice light brown color. Also, what kind of shape are your rear shoes and springs in? Where are you hearing the clunk from, the rear of the car, towards the front, or from the engine bay?
Off the top of my head, I would suspect either a broken spring in the rear drums, worn shoes, or a faulty brake booster, but more info would be nice.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 11-07-2006, 04:04 PM
I havent looked at the fluid, but when I brake, the pedal will be moving down, and then the pedal loses its firmness for a split second, and then continues going down firmly. During the split second it does that I still have brakes, but unfortunatly I cant tell where the thump(its very quiet)is coming from. The pedal also kicks back a little bit, but not much.
Old 11-12-2006, 11:01 PM
Alibi's Avatar
Interesting... Possibly a vacuum problem with the brake booster. Does this car have ABS? I hope not for your sake...
However, musyness is usually related to the master cylander. Is any fluid weeping out where the MC and the BB are bolted together?
-Eric
Old 11-13-2006, 03:58 PM
the brakes seem to have problems when Im going about 70mph and try to slow down. When I push on the brake it starts going thump thump thump(about 2 times a second) until i push hard on the brakes(once I get below 20mph) and then it stops(the thumping stops)...the brakes seem to work fine, but they make the thump(which can be felt in the pedal and heard)
Old 11-13-2006, 04:17 PM
maxwedge maxwedge is offline
A990 racer
Pull the rear brake drums and look for problems there.
Old 11-13-2006, 10:08 PM
Alibi's Avatar
Yeah, pull the drums and see what kind of shape your shoes and springs are in.
I wonder if a bad ABS wheel sensor could cause this? I hate the early ABS systems....
-Eric
Old 11-30-2006, 04:21 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
hmm i have some problem like that to... only in the morning tho the brake makes like a thump sound and if im lucky enough to push down the brake pedal i can feel it in the pedal it pushes it back up slighty and vibrates its kinda weird but yeah im used to it....
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
