Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 11-06-2006, 11:26 AM   #1
IceManQX4
Squeaking Noise with QX4
Has only experienced with their QX4 or any Infiniti where you start up the car and you get a squeaking noise?
I can almost wager that is has to do with a fan belt, as you hear it noticeably only at startup and if your turning your wheel all the way to the left or right.
I think it has to do with the fan belt just needing wd40, but can anyone confirm that this has also happened to you?
I recently just purchased a used 02 QX4.
Thanks
IceManQX4 is offline   Reply With Quote
Old 11-06-2006, 10:26 PM   #2
denisb
Re: Squeaking Noise with QX4
I would bet you're right on the money........except for the WD40 part. If it's squealing, it's probably done. WD 40 will quiet it down till you get it replaced, but it's not a fix.
Denis
denisb is offline   Reply With Quote
