Old 11-05-2006, 11:10 PM
MrPockets MrPockets is offline
push button ignition
I was watching a vid on a ford GT today, and thought the big red ignition button was pretty baddass. Thinking of my remote starter and how it works, i came to the idea that installing a push button start on my 98 GT wouldnt be too hard. If the key was already in the run position, and i heald a button that would run from the 12v constant line into the ignition line, then hit the "Ignition button" (which would be from the 12v constant into the crank line) i thought it might work. this is just me dicking with the idea, but waht are some thoughts?
Old 11-07-2006, 03:47 PM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
Re: push button ignition
im not 100% sure on the proper hook up procedure but if it works. hellw hy not. question is where would you put big red
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit
Old 11-07-2006, 08:21 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
The ricers have been putting them on Civics around here. They get the button off of a Honda S2000. If you have remote start you should have a (-) negitive trigger start wire. Just wire the switch up to that.
You'll still have to put your key in the ignition and have it on the run position.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
