Old 11-05-2006, 02:32 PM
tahoe44 tahoe44 is offline
1996 Blazer LT will not start help!!!!
question 1- if the timing chain broke would the truck turn over but not start and would it feel like there is no compression like the turn over is week, sounds very quiet. 2- if it is the timing chain how do i change it.
thanks guys
Old 11-05-2006, 02:45 PM
muddog321 muddog321 is offline
AF -Advisor
Re: 1996 Blazer LT will not start help!!!!
Probably not that - if the dist rotor is turning the cam is also and thats timing chain driven. Do you have spark? Do you have fuel pressure? Thats the two things to look at first then on from there.
Old 11-05-2006, 04:07 PM
I am going to try both mud thanks, hey how do i check the fuel preasure?
Old 11-06-2006, 12:05 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
With a fuel pressure kit available at most auto parts stores.
Be careful, the Schrader Valve is right next to some sparkplug wires and the distributor cap. I stuff clean rags around the connection before turning on the keyswitch then still pay very close attention to the connection.
Old 11-06-2006, 04:57 PM
ok i took the dist cap off and the rotor is not moving when i crank the truck. Does this mean that it is the timing belt or could it be the dist.?
Old 11-07-2006, 02:45 AM
534BC 534BC is offline
It can also be a roll pin in the dist gear sheared (if there is one like the older ones)
Old 11-09-2006, 06:26 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If engine if flooded bad from dist not turning or firing it will spin over free like low compression.
Pull the dist and check the dist gear and also roll pin as said.
I have saw a few eat up the dist gear.
Also check for dist shaft bushing wear when dist is out.
If worn out good time to replace dist.
MT
Old 11-10-2006, 11:03 AM
Blue Bowtie's Avatar
Registered Offender
If the distributor gear is intact, and the shaft is not damaged, you are likely looking at a broken timing chain (not a belt). It's not a lot of fun on a Blazer, but there are a lot worse. The accessories and the big die-cast mounting bracket are the biggest issues.
