Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-05-2006, 06:19 AM
niptuckz28 niptuckz28 is offline
oil pressure
ok i am curious about this whole oil pressure issue. when i crank the car up the pressure is up to 120. once the engine warms up it stays at 120psi. is this normal for this car. not that i am complaining as long as the pressure is past the danger zone. i have 94 bonneville non supercharger. with 187,000 mile on it.
Old 11-06-2006, 08:50 PM
Gorge's Avatar
Gorge Gorge is offline
Re: oil pressure
The oil pressure sending unit (sensor) is probably no good. I say probably because it could also be a corroded or broken wire. I'm going through this myself right now but, I'll start a new thread for my problem. I believe that the sensor on your car is just above the oil filter but, another lister with your year can confirm that. A new sensor should be about $40. Good luck.
2001 Bonneville SE
2006 Durango Ltd Hemi
1990 Ford F-150
1996 Kawasaki GPZ 1100
