Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-05-2006, 05:46 AM
niptuckz28 niptuckz28 is offline
brakes problem
ok i have a brake problem as well. when i press the brake pedal it feels like air or something is in it. the car stops but it feel like when press the pedal half way it goes down to slow down it goes all the way down. also the abs light is on.
Old 11-06-2006, 06:05 PM
jdq jdq is offline
Re: brakes problem
check brake fluid, is it full .Maybe air in system , could need bled ,possible leak , did they say when they were replaced when u bought it.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 11-13-2006, 12:32 AM
jonsonton's Avatar
jonsonton jonsonton is offline
Re: brakes problem
Under heavy braking periods the fluid can heat up and even boil, so air is a possibility. First you should probably would check for leaks.
