Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-04-2006, 08:33 PM
Watache Watache is offline
1999 SL2 Automatic, Which engines will fit?
Have 1999 SL2 which uses 1 quart of oil in 300 miles and engine is noisy. What used Saturn engines will fit? Assume the SL2 means dual overhead cams. Mine is.
Old 11-05-2006, 03:01 AM
PlayStation3 PlayStation3 is offline
Re: 1999 SL2 Automatic, Which engines will fit?
only the saturns 1.9 liter will fit directly in the bay with no mods.
Old 11-05-2006, 04:38 PM
Thanks. I'm a bit dense though, on what models have the 1.9 liter. Did it come in a variety of years. Anything earlier than 1999 for example.
Old 11-05-2006, 07:41 PM
all of them where 1.9 they where dohc and sohc but the 91-94 i think had a different version of the sohc
Old 11-16-2006, 10:31 PM
tech 28 tech 28 is offline
1999-2002 Dohc
Old 11-20-2006, 08:50 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
the 1.9 engine, weather SOHC or DOHC, was restricted to saturn S-series cars. the dohc engine changed mid year in 99. the most noticible differance is the placement of the throttle body, ether to the side of a aluminum intake(earlier) manifold or on top of a plastic manifold(later). i'm not sure what problems would arise from swaping the 2 designs(wiring harness would be a issue) but if you have the earlier design, a 98 engine will drop in, and i beleave back to 95 will work with swaping the fuel rail and a few other parts. for the later design, 2000-2002 should work fine.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
