Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-04-2006, 07:26 PM
speeddevil's Avatar
speeddevil speeddevil is offline
87 Caprice Ls Parking Light Problems
I own a 87 Caprice Ls V6 4.3l. i recently noticed that my parking lights as well as gauge cluster and dash lights do not go on. checked all my fuses and all are ok. though i did not find a fuse spot for parking lights on my fuse box. headlights light up properly as well as turn siganls and stop lights. hazards work as well. cant seem to pin point problem. i wanted to check the actual switch but i do not know how to get to it can anyone help or know something aboput this.
Old 11-04-2006, 09:18 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 87 Caprice Ls Parking Light Problems
Double check the fuse for the tail lights. Another possibility is the headlight switch itself.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-04-2006, 09:32 PM
speeddevil's Avatar
taillight fuse checked i also think switch might be bad but i have no idea how to get to it or get it out off its location is there such a website to document this step by step?
Old 11-04-2006, 09:53 PM
silicon212's Avatar
Confoundingly Lucid
I am not sure about a website, but the switch can be fairly easily replaced. There are two 7mm-headed bolts that hold it in from behind the dash - one on top and one on bottom (yes, I have had to replace the switch on mine as well). Pull the wire harness off, become a contortionist and pull those two screws off. The switch pulls out from behind, assembly is the reverse of removal.
Old 11-05-2006, 09:36 AM
speeddevil's Avatar
but how did you actually get to the switch itself i have no room to get to it.
Old 11-05-2006, 09:50 AM
silicon212's Avatar
Confoundingly Lucid
There's the access plate under the steering column, which has 4 bolts holding it on - two on top and two underneath. You have to take this off, then you use a small ratchet drive (I used a 1/4" drive Craftsman ratchet with a 3" extension and 7mm socket on mine). You might have to pull wires back out of the way, ditto the A/C duct that's in the way, but believe me, this can be done. It is helpful to have a mirror handy.
I'm also of a thin build and at 6'3" that means I have long, skinny arms which are ideal for car work.
Old 11-05-2006, 10:00 AM
speeddevil's Avatar
gonna have to try it just hope all my alarm and remote start wires are not in the way. last question is bolts are sitting behind or on the side of the switch?
Old 11-05-2006, 11:28 AM
silicon212's Avatar
Confoundingly Lucid
Old 11-08-2006, 05:18 AM
87BoxClassic's Avatar
87BoxClassic 87BoxClassic is offline
i had a similar problem, i put all brand new bulbs in and it worked. i have a 87 caprice classic
Old 11-08-2006, 11:21 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
87BoxClassic, How did you happen to blow all the lights at once? Did a spike of electricity flow through your electrical system?
Old 11-08-2006, 06:23 PM
i didn't my neighbor who is a 68 yr old man told me that he used to have to replace all 4 when he lost one because the circuit wouldn't complete correctly
Old 11-08-2006, 06:40 PM
silicon212's Avatar
Confoundingly Lucid
That's simply not true. The lights are all wired in parallel, not series, so a failure in one will not affect the rest. The turn signals will stop flashing in the direction of a failed turn signal bulb, but all other filaments on that circuit will continue to light.
Old 11-09-2006, 12:09 AM
i beg to differ.... take a light out of one of your parking lights in the front and when u use the other turn signal they flash top then bottom insted of top and bottom at same time. i'll take videos if you would like me too
Old 11-09-2006, 09:04 PM
speeddevil's Avatar
well i got the lights to work definately bad switch brocken terminal. though i was not able to get to the switch through the access panel, i removed dash enough were i was able to get to it. thanx for your help guys.
Old 11-09-2006, 09:12 PM
silicon212's Avatar
Confoundingly Lucid
The question was would all of the lights fail - as in all dark - if one burned out. That doesn't happen. The flash rate changes, but the other lights remain lit.
Speeddevil, I'm glad to hear you got it working again.
