Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 11-04-2006, 06:55 PM
wanderingmind wanderingmind is offline
1987 Lebaron GTS - "power loss"
Hey all-
I just picked up a 1987 Lebaron GTS Turbo today for $300. It's got a couple problems. I am going to have to replace the drive axle and it leaks a bit of oil. Here is my question. When I go anywhere near WOT, it will pull nicely for a second or so, then it will cut out (fuel cut off???) and it will flash "power loss." What is this? My best guess is that the computer might be sensing too lean of an a/f ratio and is cutting the fuel and possibly then pushing all the boost through the wastegate. Am I right or is it something else? If I am right, anyone know how to fix this? I threw in some fuel injector cleaner today.
Old 11-06-2006, 03:25 PM
Joric theredbaron's Avatar
Joric theredbaron Joric theredbaron is offline
Arrow Re: 1987 Lebaron GTS - "power loss"
I posted this responce to PFC Gardner's post 10/23 askin a similar ?? on his 2.5 that bogs..
Sounds like a fuel problem, possibly blocked in the filter area, or worse a partially blocked catalyst, try taking the cat off an see what happens, apart from the noise the revs shud fly up. So its a cheapy fix if its filters.. or a few $$$ more for a catalytic converter..
Theres also a post from Kmaniac on the same site thats longer and gives some other things to look for.. check it out.. might be helpful
Joric
Friends dont let friends drive imports
