Old 11-04-2006, 11:00 AM
Dan789ca Dan789ca is offline
Exclamation 89' Grand Prix Problem(Please help.)
Well.. I hope this doesn't stump you car guys also.
I have an 89' Grand Prix Se. 3.1l V6
For about a month now it's been undriveable. The car starts with no problems and idles properly, but once you hit the gas the car chokes and either shutters and doesn't go or just stalles out.
Any ideas?
We have already ran the car into the computer's and we had 2 code violations come up and fixed them and alas it still didn't do anything.
the 2 Codes were: O2 sensor, Vacuum leak.
please im a College student who is running out of money!! Please give me some good suggestions
Old 11-04-2006, 11:12 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 89' Grand Prix Problem(Please help.)
Welcome to AF!!
Check the throttle position sensor to make sure it is working right and if you haven't already done so try unplugging the torque convertor solenoid on the top of the transmission. If the TCC solenoid is stuck it can cause the stalling you describe.
Old 11-04-2006, 11:52 AM
maxwedge maxwedge is offline
A990 racer
I'd also suggest checking the fuel pressure.
Old 11-04-2006, 11:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I'm with Max, sounds like a fuel pressure issue to me too. Does it only die in gear, or does it die with throttle application in park/neutral too?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-04-2006, 12:27 PM
It does it in park and Gear.
Fuel pump and everything is fine
Old 11-04-2006, 12:37 PM
richtazz's Avatar
How did you determine the fuel pump is fine? What is the fuel pressure at the schrader valve on the rail?
Old 11-04-2006, 03:28 PM
A990 racer
Thumbs up Re: 89' Grand Prix Problem(Please help.)
Rich, just was going to ask the same thing! It's another "all the answers but the right ones"! Everything is fine???
Old 11-08-2006, 10:16 PM
hallboy hallboy is offline
If you slowly apply the pedal does it rev or die?
How is your spark? Have you checked your plugs and or wires or even be sure they are firmly connected?
I just dropped $85 on a computer service check and the Goodyear place says "Take it to this electrical specialist we work with". Of course they want another $80+ just to check it again. I took it home checked all my plug wires and found one to be iffy. $25 bucks later it was the wires.
My point is it could be very simple. Don't pass up on any advise from these guys. Good luck.
Old 11-10-2006, 07:17 AM
Yeah, all the plugs have been changed and wires were changed also. Still nothing. The idle will raise when you rev slowly but will not go past 2000rpm or it chokes and stales, unless you let go of the gas then it goes back down to the idling rpm.
We now have it at another shop putting it on there in-depth analsys machine.. 130$.. hope they come up with something
Old 11-10-2006, 04:03 PM
Bump
Old 11-11-2006, 08:50 AM
richtazz's Avatar
post your fuel pressure readings. We can't offer any other help until you do, as I still believe you have a fuel pressure problem.
Old 11-11-2006, 02:45 PM
umm, I believe its 47psi.
Old 11-12-2006, 06:07 PM
richtazz's Avatar
47 psi running, key on/engine off, or with/without fuel pressure regulator vacuum hooked up?
Old 11-12-2006, 07:55 PM
key on my friend Hoses on
Old 11-13-2006, 08:00 AM
richtazz's Avatar
ok, then next, take a reading with the car running and the regulator vacuum attached. the pressure should drop 3-7psi, no more. With the car still running disconeect and pinch/plug the vacuum hose (to prevent a vacuum leak) and the pressure should shoot up to near the original key on/engine off reading. If it fails either of these tests, the fuel pressure regulator is bad. If it passes these tests, you need to check spark and injector fire patterns as the vehicle begins to break up. A spark miss may indicate a cranks sensor or ignition module breaking down at higher RPM's. On the plugs and wires, what brands did you install?
