Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-04-2006, 09:05 AM
bembro2 bembro2 is offline
1986 Suburban - Strange Tranny Problems
After driving around in my '86 suburban through the heavy snow after a recent blizzard, my transmission began acting strange. Now, while if I'm driving in 2WD and brake fairly hard to a stop, none of the gears work. However, if I grind into L4WD, all the gears work once again. The fluid level is correct. Any ideas?
Old 11-05-2006, 07:46 AM
86Sub 86Sub is offline
Re: 1986 Strange Tranny Problems
Check the vacuum line to the transmission. You may have knocked it off.
Old 11-05-2006, 02:29 PM
Blue Bowtie's Avatar
Registered Offender
Just guessing, but an '86 MAY have the TH700-R4, and therefore use a TV cable instead of a vacuum line to a pressure modulator. Does the trans seem to operate normally if you manually run through the gear ranges?
Old 11-06-2006, 09:18 AM
idmetro idmetro is offline
Can't speak for all of them by my 86 burb has the 700R4 and definitely does not perform without the TV cable. It's attached to the throttle linkage but instead of going into the cab it goes down into the trans on the passenger side. Check to see if yours is broken.
Old 11-10-2006, 10:24 PM
troy1 troy1 is offline
AF -Advisor
Sounds like a transfer case problem to me.
