Old 11-04-2006, 06:05 AM
drnoel drnoel is offline
'91 S-10 High Idle
I recently purchased a 1991 S-10 w/132K miles on it. When I start it, the idle is understandably high, but even after warming up, the idle is still high. Has anybody experienced these problems?
Thank you.
Old 11-04-2006, 10:55 AM
tom3 tom3 is offline
Re: '91 S-10 High Idle
Ran into this a couple times, usually a vacuum leak. The fuel inj. will compensate up to a point but a leak will make it idle faster. And a bad temp sensor reading to the ECM will also cause this. A scan of the ECM will usually pinpoint this deal. Look for real low counts on the IAC (idle air control) and the coolant temp readout.
Old 11-04-2006, 10:56 AM
jdl jdl is offline
You didn't list an engine size? If this vehicle has a speed density system, then a vacuum leak, could cause the idle to go high.
Did you check for trouble codes?
Did you check to see if the throttle valve is closing? What does the tps sensor show?
Old 11-04-2006, 03:18 PM
Thank you, I will check for a vacuum leak.
Old 11-06-2006, 01:45 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
also remove and clean the IAC valve in the side of the TBI unit, commonly is all carboned up and it controls idle speed
just unscrew it from the unit and use carb cleaner real godo on it and also in the hole in the tbi unit it comes out of and then compress air blow it all out good
lots of black crud in there, get it out
if its really bad then you should remove the unit and do it from underneath too
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 11-06-2006, 03:14 PM
Thank you for your response.
I am a neophyte at this.
What and where is the IAC valve? What and where is the TBI unit? Will I need any special tools?
Thank you again.
Old 11-06-2006, 05:52 PM
hi there the IAC is the big thing sticking out of the side of the tbi on the passenger side of the unit and has a big 1" or so hex on it for a big wrench to fit it
a coupel wires plug into it, usually four and is a square plug shaped like a transmission converter lockup plug is
cant miss it
look at this too:
http://autorepair.about.com/cs/troub...042603a_08.htm
your distance of pintle extension should be 1 and 1/8"
good luck
Old 11-06-2006, 06:20 PM
Thank you very much, I am now ready to tackle this job.
Old 11-11-2006, 08:23 PM
tangz tangz is offline
Send a message via MSN to tangz Send a message via Yahoo to tangz
Has there been any progress on this issue? I have just about the same issue with my 95 S10. We replaced all of the bad hoses we saw, I cleaned the throttle valve and I also replaced the throttle sensor (which was sort of strange because I had to turn it 1/4 cm clockwise to get it flush, then turn it back to be able to put the screws in)
2 weeks prior I had to replace the power booster because my brakes no longer were "easy" to use ~ I dont know if this relates to the problem, but everything I have googled so far the high rpm's and brakes seem to go hand in hand for some odd reason.
Old 11-12-2006, 03:48 PM
I did clean it, and it seems to be a bit better. It was dirty.
