Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-03-2006, 11:59 AM
dxtrboygnius dxtrboygnius is offline
2001 Chevy Venture engine temp sensor.
Hello! I was just wondering where the temp sensor is located. My van has two fans, I get power to both but they will not start. I am also looking into relay problems. Any advice would be welcome. Thank you.
Old 07-04-2007, 06:06 PM
neoflee neoflee is offline
Re: 2001 Chevy Venture engine temp sensor.
I have same probs, checked fans to see if they work when they have power and they do work, but they are just not turning on. All fuses are good, replaced temp sensor, and still nothing
Old 07-09-2007, 01:55 AM
rockwood84 rockwood84 is offline
temp sensor is located by the thermastat follow the top radiator hose good luck
Old 07-09-2007, 01:58 AM
one more thing check the plug below the hood latch its the main plug for both fans
Old 09-19-2014, 11:37 PM
Primal Fury Primal Fury is offline
You will need a 19mm deep socket a u joint and a rachet ( I used 1/2").
Get a hooked pik and locate sensor below thermostat housing. rightist middle of engine.
Beside that black metal eye hook ..used for lifting the engine. .. remove the connector carefully .place bucket undermeath to catch coolant . then proceed carefully to remove coolant temp sensor. Its really tight on that area.
I put a rag just below the hole.. so it will not fall down there and get lost. Carefully screw in new sensor into hole ..watch end part ..of I slip up u will break sensor !! replace connector
Dont overtorque ..thats it !! Wipe sweat off brow, starter up and check for leaks.
Old 09-20-2014, 12:00 PM
Tech II Tech II is offline
Newbie, check the date.....post is 7 years old...
Old 05-24-2015, 03:02 PM
JustAguy78 JustAguy78 is offline
Jerk, it was still helpful...8 years now...Thanks Primal Fury.
