Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 11-03-2006, 12:57 PM
LavendarLady LavendarLady is offline
Smile 1996 Lincoln Continental Fuse Schematic
I hope someone can help. Does anyone know where I can find a fuse schematic for a 1996 Lincoln Continental Diamond Jubilee? I had a my injection system cleaned and the next day my automatic lights went out and so did my brights. I don't know if there is any connection, or something may have been knocked loose by the mechanic. I suspect it is a fuse, however, without the schematic I can't determine where is located.
Any advice would be greatly appreciated.
Old 11-03-2006, 06:07 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 1996 Lincoln Continental Fuse Schematic
Looks like you'll need to see #16 in the Power Dist. Box under the hood
1996 Continental
ELECTRICAL DISTRIBUTION
Wiring and Circuit Protection
Fuse Junction Panel
Location
The fuse junction panel is located to the left of the steering column under the instrument panel.
Power Distribution Box
Location
WARNING:
ALWAYS DISCONNECT THE BATTERY GROUND CABLE BEFORE SERVICING "HIGH-CURRENT" FUSES. IT IS RECOMMENDED THAT THE "HIGH-CURRENT" USES BE REPLACED BY A QUALIFIED TECHNICIAN.
The power distribution box:
Is located in the engine compartment on the LH fender apron next to the battery
- Is used in place of fuse links
- Is part of headlamp dash panel junction wire (14290)
Content
The power distribution box contains:
- A 175 Amp mega-fuse
- High amperage maxi-fuses
- Low amperage mini-fuses
- Relays for powertrain control module, horn, blower motor and high beam headlamps
Refer to the following illustration for specific content of the power distribution box.
-Steven
1996 Town Car, Cartier
