Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-03-2006, 07:51 AM
bass440 bass440 is offline
'92 Talon - No Tail/Dash Lights
On a '92 Talon, where is the fuse for the tail lights and dash lights? There weren't any fuses for these circuits in the under-dash fuse block. Is there a fusible link or something that controls these circuits?
I don't have a book of any kind. This is a friend's car that I'm asking this question about.
Thanks for the help.
Old 11-03-2006, 08:20 AM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Re: '92 Talon - No Tail/Dash Lights
It should be in the fuse box somewhere by your clutch pedal or that general area. The name of the fuse is illum, someone correct me if I'm wrong.
1992 Ẽfini RX-7 FD3S
Old 11-03-2006, 10:41 AM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
ive had messed up light problems lately too my turn signals just stopped working i replaced all the fuses the flasher unit the bulbs and they still dont work
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
