this looks like a great site--- when i turn key on and wait for fuel pump to quit running and turn engine over, engine will start and run for a for about 30 seconds and stop. will start again if i wait for pump to stop running. If i pump the pedal really fast it will struggle to keep running for a couple minutes. have replaced fuel filter, can anyone give me a hint to my next step???
Re: 1993 buick 3800 gs wont keep running
Welcome to AF check your fuel pump pressure at the rail.
Thanks, fuel pressure at rail is only 8 psi, what should it be???
BTW - What do you get at ignition to on not start (fuel pump prime position)?
I had the same problem with my 1999 GSE . It ended up being the fuel pump was restricted by a build up of tarnish on the screen on the fuel pump itself. I had to replace the pump . I was told this was due to ethanol that has been added to the gas. It had taken the tarnish off the inside of my tank and sent it to the pump clogging the screen and choking my fuel filter. I dont know about yours but the fuel pump for mine cost 400 bucks(not including labor). Good luck.
