Go Back   Automotive Forums Car Chat > Ford > Festiva
Old 11-02-2006, 09:44 PM
tampabay06 tampabay06 is offline
1999 Gearbox help
My reverse, 1st, 2nd, 3rd and 5th gears all work perfectly fine. I can shift into 4th gear however after about 200 metres the gear stick moves into neutral for no apparent reason. Does anyone know what the problem is and if possible what a mechanic will charge me to get it fixed.
Old 11-19-2007, 05:08 PM
C. Cleve C. Cleve is offline
Re: 1999 Gearbox help
Hi, This is from a retired ford tech, You have a worn synchro in the transaxle, If you can live with the problem that's ok, If not, Its time for a rebuild, Current prices in the midwest at a union shop are about $99 per hour, About 8+ hours labor + parts.....Good Luck, Clay....
