Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 11-02-2006, 08:57 PM
denniro denniro is offline
2001.5 speed sensitive door locks overactive, help!
I've had my 2001.5 for about 3 days now. I've just noticed the rear door locks operating in a seemingly random manner. One side, on one instance, the other side on the next, lock, unlock, slow speeds or fast. I'll keep the radio down and pay more attention to when it's happening for better diagnosis. Please help anybody!
Old 11-04-2006, 07:21 AM
brettasnell brettasnell is offline
Re: 2001.5 speed sensitive door locks overactive, help!
Sometimes the switch can go haywire, causing the door to lock and unlock at random. It is most likely doing it while you are not around the car also. Simple solution would be to disable the power to the locking unit. There is one for each door, there may even be a fuse for the rear doors only (i can't remeber). Good luck!!!
Old 01-02-2007, 04:36 PM
VW816 VW816 is offline
i have on 01 passat and occasionally the lock on the back door goes haywire... thats the only real complaint i have about my car so far is that its had a couple little electrical glitches, but sorry i dont know what to do to fix it
Old 01-03-2007, 08:11 AM
Will12 Will12 is offline
Microswitches are known problem with B5 passats. Once I tried to fix one in the trunk and it works randomly (when opening trunk light is off or on). Change the switch (I think that there is a revised one) or disable it.
Old 01-03-2007, 09:24 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I have seen issues with the comfort module on passats. Its located under the driver front carpet and in some cases the wires get corroded and short out the module. If there is more than one door that is randomly locking/unlocking i would think it would be the comfort module thats faulty.
Old 01-04-2007, 07:35 AM
Can comfort module be repaired, and if not, how much is it?
Old 01-07-2007, 10:16 PM
VDUBMAN
no repair.
They can be spendy 2-400.00
