Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-02-2006, 08:01 PM
Allen13 Allen13 is offline
Question 99 Mercury cougar starting problem
Keeping my fingers crossed that someone can provide some advice for a problem with my 99 Cougar...
One day in June my car wouldn't start. Garage said it was the timing belt. Replaced the belt and car ran fine. Two weeks later it died again. This time the mechanic put on a full "kit" and timing belt. Car ran fine again until early August when it started having the problems that are still plaguing it.
I had trouble getting the car started one morning. Drove it around the block and it stalled three times. I was out of town so took it to a different garage. The car ran fine the entire time it was there, not stalling once. Mechanic guessed that it was the fuel pump, as it was measuring quite low. With a five hour drive home and an unreliable car I had it repaired. Car then ran fine for three weeks.
Then it started stalling soon after starting. At first it stalled between when I shifted from reverse to drive. Didn't seem too big a problem at the time, as it was infrequent and only after the car had been unused for some time.
Early September the problems worsened. It was hard to start the car and sometimes it would die right after turning over. Garage had trouble diagnosing the issue. They kept it for a few days to start it up in the morning and taking it out on the road. Ran a lot of tests and their best guess is that it has "cold starting" problems. They don't seem to have a fairly certain answer, just guesses, and at this point I don't want to continue to pour money into my "red lemon".
Rarely use the car now, and when I do it takes up to ten minutes of idling and pumping the gas pedal just to get the engine to warm up. Usually when I get it running it will run until I turn it off, but from time to time it will stall on the road, usually when I decelerate for a light or when I'm making a slow turn. As you can imagine I don't feel particularly safe driving it so I've been hesitant to use it.
Can anyone help?
Old 11-02-2006, 08:38 PM
cougar4life cougar4life is offline
Re: 99 Mercury cougar starting problem
Is your car the 2.0 I4 or the 2.5 V6?
OH and I would recommend checking out www.newcougar.org/forums
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
Old 11-10-2006, 10:08 PM
$Priceless$ $Priceless$ is offline
You might want to check the fuel pump....or try to clean out your gas tank....that might help...
Old 11-12-2006, 06:16 PM
youasked4help youasked4help is offline
on the 99's the "Fuel Pumps" are mounded high, meaning you better keep gas in the tank. Those pumps get hot and the gas sloshing upon them cools them. thats why you should keep gas over half tank in your car.
The other thing that can keep your car from starting is a malfunctioning crank sensor, this is located on the "Transmission housing" on the front of the moter, it points to the flywheel, you have to break the trans away from the engine to replace it.
i have also read that some switches on your stearing wheel windshield wiper delays etc,,, can cause this problem. I wish you the best of luck, my cougar is a pile of junk at 50km.
Learn Steps to painting a car www.you-asked-4-help.com
Old 11-26-2006, 08:12 PM
rhandwor rhandwor is offline
Check your fuel pump ground it should be in the rear of luggage compartment.
A loose ground will cause problems. Check eec ground right kick panel.
Old 02-14-2007, 10:27 AM
stevenjm2 stevenjm2 is offline
is it accessible from the trunk? thanks
Old 02-14-2007, 07:13 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
How-to on the cougar forums suggested above.
http://newcougar.org/forums/showthread.php?t=90734
Or try the easier way.
http://www.contour.org/mods/mods.php...o&displayid=39
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
