Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-02-2006, 06:09 PM
Cross69 Cross69 is offline
Angry 99' Burb 4WD Rear Drums
Does anyone have any idea how to get the rear drums off or even WHY they would not come off? In park, emergency brake is off, tire off and drum will NOT come loose... About to drop a match in the gas tank.
Thanks in advance for any help or ideas.
Old 11-02-2006, 06:51 PM
2000CAYukon 2000CAYukon is offline
Re: 99' Burb 4WD Rear Drums
Rust is usually the cause. Carefully, using a hammer, hit the drum between the wheel studs. Never hit the drum on the outside. Only hit the flat parts between the studs. The bigger the hammer the better. You can also spray some PB Blaster to help loosen the rust.
//2000CAYukon
Old 11-06-2006, 11:14 AM
Blue Bowtie's Avatar
Registered Offender
Try it in neutral so you can spin the drum to help extract it.
Old 11-07-2006, 03:48 PM
//2000CAYukon
BINGO! Used WD-40 for 2 days to be safe, set a bar in behind on the flat edge and smacked it\them 1 time and popped off with not a single problem.
Thanks
