Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-02-2006, 10:11 AM
souphmars souphmars is offline
98 ranger will not start
it is 4 a banger - went out this morning to start and would not start - it tries to start- it cranks over then cuts off immediately - any clues - its almost like it gets gas or fire for like a second, then it quits - thanks in advance
Old 11-02-2006, 10:20 AM
12Ounce 12Ounce is offline
Re: 98 ranger will not start
After it stops, after turning the key OFF but before turning ON again ... test for fuel pressure on the fuel rail. You don't need a gauge, just cover the tip of a small screwdriver with a rag and press the nipple in the Schrader valve. Gasoline should flood out for a brief period ... enough to wet the rag. BE CAREFUL!
Old 11-02-2006, 09:25 PM
i checked it - it had a good amount of gas come out - so it must not be getting an spark - on saturday i will see if it is not getting any spark - it is doing the samething my wife's car did when the coil pack went out on it - i am starting to wonder if it is the coil pack
Old 11-04-2006, 09:40 PM
its got good fuel pressure - fuel is getting to the rail - it has good spark - timing belt is still good - any clues?
Old 11-04-2006, 10:50 PM
e_powers e_powers is offline
timing belt is still good but did it jump any cogs?
starting to love my 93 ranger w/3.0 5 speed.
Old 11-05-2006, 07:40 AM
Are there any codes?
Old 11-05-2006, 08:53 PM
well i got it fixed - there was no codes- it was weird - it was the idle air control valve - now it starts right up - i figured this out after i replaced the crankshaft position sensor- i am just happy to have it running again
Old 11-05-2006, 09:08 PM
markdpro markdpro is offline
Well a peculiarity of this engine is that it will run with the Crank pos sensor out but not start so you may have got it on the first pass.
Old 11-06-2006, 06:08 PM
well i replaced the cank pos sensor and it still would not start - my father in law got out there tapping IAC and it fired right up -
Old 11-15-2006, 11:33 PM
DonSor DonSor is offline
An OBD could've given you the appropriate code which pinpoints the problem. I have 1999 Ranger 4.0 and I use the OBD II but earlier models I believe use the OBD I.
Don
Old 11-16-2006, 05:29 AM
Don
95-now use obd2 i believe
