Old 11-01-2006, 11:45 PM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
start car down hill?
someone told me this.
if you run your car down a hill while its not running, you can put it into 1st or 2nd gear and the engine will start.
ever hear of that?
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 11-01-2006, 11:51 PM
MishaA's Avatar
MishaA MishaA is offline
Re: start car down hill?
Did it many times, when my battery went dead
Old 11-01-2006, 11:53 PM
does the key have to be in the ignition? i would guess so
90' Honda Civic Si
Old 11-02-2006, 12:01 AM
MishaA's Avatar
Yep, of course, you want your ignition to be on for engine to work. There is no magic to this, you just use your transmission as a starter to spin the engine. And if you have two or more people, you even don't need a hill - well, depending on particular car . Second gear will be easier on your tranny by the way.
Old 11-02-2006, 01:32 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yes, the way your engine starts is by a motor spinning the engine, of course your ignition must be on, or you'll get no spark and no combustion. The transmission, when in gear, will spin the engine, the higher you gear you put it in, the less force the transmission will need to turn it, but the slower the engine will spin. Its called push starting, or bump starting, im sure it has many names.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 11-02-2006, 02:28 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Sigh, one of the beauties of driving a stick.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 11-02-2006, 03:38 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thumbs up Re: start car down hill?
As long as you have a stick stick it will work.
I learned that about 50 years ago.
They told me when I was done driving for the day always park it on a big hill so you could pust start it the next day.
MT
MT
