Old 11-01-2006, 10:29 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Powercoating.
I just got my powdercoated valve cover. I decided to go with white and I think it turned out perfect. Anyhow, someone was saying that I need to make sure to clean it up. What should I do to clean it up? Second, I want to paint the lettering red. What would be the best way to go about that?
Here is the valve cover:
Old 11-01-2006, 10:33 PM
miami3000gt miami3000gt is offline
Re: Powercoating.
wow looks cool where did they do it and how much is it?
Old 11-01-2006, 10:45 PM
Polygon's Avatar
The Red Baron
Re: Powercoating.
A member on 3Si did it for me. It was $93 shipped and he will give you a $45 core charge if you send him back your old one.
Old 11-01-2006, 11:11 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Powercoating.
the suggested cleaning of a part after it is powdercoated is to remove any sand that was used to strip it of paint originally in the process. when i got my powdercoated valve cover, it had some sand on it. i would blow it out/off with an air hose. there is always fear that the sand would be circulated through the oil and could get caught in a bearing and do some damage. that's worst case scenario though.
Terry does a nice job, doesn't he?!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-01-2006, 11:19 PM
Polygon's Avatar
The Red Baron
Re: Powercoating.
Yeah, I'll be sending him some other stuff to do.
Old 11-01-2006, 11:44 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Powercoating.
Looks good. I see you also got the valve cover off of a 3000gt instead.
Poser!
j/k
Old 11-01-2006, 11:53 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Powercoating.
That looks good I have never really seen a white valve cover before.. ere you from polygon?
Old 11-02-2006, 12:12 AM
AutostradaVR4 AutostradaVR4 is offline
Re: Powercoating.
y not leave the polished lettering? damn that looks good!
I would just use brake caliper paint, but i think any high heat stuff should do the trick.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-02-2006, 10:40 AM
Polygon's Avatar
The Red Baron
Re: Powercoating.
Poser!
j/k
Hehehe, I'm glad someone noticed.
Yeah, that's kind of why I went with white. Everybody is doing red so I thought I would do something different, plus it matches the car. What do you mean, am I from polygon? I'm from Utah. . .
I could do that and polish the lettering instead. That might be better since I want to go with a polished intake manifold.
Old 11-07-2006, 09:10 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Powercoating.
Looks very good man! Make out with me! .. JUst kidding.. haha
I really wnat to get mine done! but im thinking of doing it myself, just for fun.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 11-07-2006, 11:02 AM
Polygon's Avatar
The Red Baron
Re: Powercoating.
They sell powdercoating kits. Then all you need is a big enough oven. Just don't ever cook food in it again.
Old 11-07-2006, 04:16 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: Powercoating.
Glad to hear it turned out well
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 11-08-2006, 05:43 PM
liquidPunk's Avatar
Re: Powercoating.
ummm... Ill use my sisters hahaha.
-More to come-
