Old 11-01-2006, 08:02 PM
3mikeman 3mikeman is offline
Dash Cluster
I want to remove my cluster from my 99' silverado to send it out for a trans temp gauge to be installed. Is there anything that should be done before disabling the dash area. Like air bags or any other electrical items?
Old 11-02-2006, 07:13 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Dash Cluster
Just order a new cluster with it already installed.
*Under Construction - New sig to debut*
Old 11-03-2006, 12:46 AM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
Re: Dash Cluster
Or you can get a used escalade cluster off of ebay for cheaper I'm sure. Plus the gauges look better IMO.
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 11-03-2006, 06:51 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: Dash Cluster
Don't you have to have the computer EPROM reflashed so that it knows there is a gauge to power?
Old 11-04-2006, 11:20 AM
Re: Dash Cluster
Nope, simply plug and play.
Old 11-07-2006, 07:29 AM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
Re: Dash Cluster
NO PREP NEEDED. Just set emergency brake, turn ignition to unlock shift lever, put the steering wheel in the tilt down position, put shift lever in the lowest position, pull the bezel loose and remove, unscrew the cluster and unplug. Reinstall in the reverse manner.
About a 5 min (literally) job.
T
"What in the wide, wide world of sports is a go'in on here?" - Taggert
