Give me some ideas on what to check
I started my crx for the first time last thursday, a couple little bus, but nothing major. Fiddled around and had it almost all done except 2 codes, 14 - IACV and 20- Electric load detector.
Well, the car is at my shop and I've been pulling it in abd out of the shop daily to make some room, it always fires right up no problems. This has been for about a week. Last night I went to start it, and it almost fired up, but didn't. Subsequently, every time I tried to start it after that, it would just crank over. We can smell fuel in the exhaust (it's open manifold at the moment) and there is spark at the spark plugs. Where should I look?
Re: Give me some ideas on what to check
Have you tried cleaning out your IACV? Code 20 is difficult to diagnose, I say start by checking all your grounds: tranny, thermo housing (probably rusted, get it cleaned), and valve cover.
1989 Civic STD - sold 1991 CRX Si - current Free Service Manuals: http://hondatech.info/ |
Code 20 is electrical load, alot of times cars will have old stereo equiptment installed and removed, or installed incorrectly which will create a short or load and throw that coad, but Id try the tips mentioned above first. The IACV, if it isnt bad, can be cleaned and it usually helps. If you do a quick search youll find plenty of ways to do it.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Actually, I'm gonna go by the shop and make sure it's not out of gas, I tried to start it yesterday after it sat a while and it almost started and then wouldn't.
Yeah, d15b vtec on an '89, running a p28 and obd1 conversion. I'm going to make sure I have all thr grounds in place, After I put some gas in it.
Hope this helps.
cool, I'm going to work on it today, we'll see what happens, thanks for the tips.
not to be a thread jacker, but my car does kinda the same thing. i just fiddle with the gas pedal a lil and she fires right up. but i got a 90 si with a b16 obd-1 p28.
mine smells like gas a lil too, but the motor still needs a breakin.
-tony- 2000 honda s2000 |
Finally got a chance to work on her this morning. I started thinking about the symptoms and how abrupt is stopped running, pulled the line off the FPR and no gas, hahaha. I had removed these tacky APC indiglos off the car and it appears I put the needle about 1/8 of a tank off and I just didn't snap that it was that low in the first place.
Now about that IACV, is that the one behind the intake manifold with the coolant lines running underneath it? I took that off and cleaned it out. Or is that the one under the throttlebody? Either way I still have code 14. I will look into it later as I have to work now.
No, you cleaned out the right thing. The thing underneath the throttle body is the FITV, it gives your car a mini vacuum leak when cold, so its can idle a little high. Since your code 14 didnt go away when you cleaned out your IACV, you might have the miswired it like bambam said.
