Old 11-01-2006, 12:13 PM
someguy000001 someguy000001 is offline
Fuel fitting problem
I'm trying to replace the fuel pump on my '97, but the center fitting on the pump is driving me nuts. The two outside lines came off no problem, but the center one is a different type. I got a 3/8" fuel line disconnect tool (ampro t70101) from my local parts store, but it doesn't seem to fit. I'm trying to put it over the outlet and slide it into the fitting? Is that right?
There are plastic ridges that keep the tool from clamping on the inlet, and I can't get it from the side since I can't go around the other outlets.
I'm dirty, scraped up, and miserable. Any tips?
Old 11-01-2006, 12:41 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Fuel fitting problem
If your replacing a postively dead pump, you could break off the outside connectors to give you some room, or use a couple of some flat-bladed screwdrivers to depress the "fingers" so it'll pop off, or you could get a disconnect tool that hinges like scissors with a tool on each end.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 11-01-2006, 01:58 PM
Thanks for the reply. I never thought to just cut off the nubs. I get stupid when I get frustrated.
I shoved my digital cam up ther for a better look.
I just went out and got another fitting tool, but I'm having the same problem. The little ridges (circled) prevent it from sliding onto the outlet pipe.
So I take it the fingers are where the arrow is, on the sides? I think that's my biggest problem: I don't know how this connector works.
I'm gonna get back into it. Thanks again.
Old 11-01-2006, 03:15 PM
Well, I got it off. I used a plastic fitting tool that you stretch over the outlet pipe. The ridges I mentioned before kept it from going on cleanly, so in a fit of anger I twisted and warped the plastic tool until it bent around the ridges and finally it kind of went in and popped it off.
For me this is further proof that automotive engineers are evil, angry people. They go out of there way to make things difficult, and I bet they laugh about it over beers after work.
Old 11-01-2006, 03:29 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
That type is the old squeeze it type.
Just squeeze the plastic ring at widest part with fingers or pair of pliers.
A little practice and it works good.
Good picture.
Yours looks like a tight fit to install try squeezing the end or twisting it a little.
And on outside lines you will need to use your old coupler snaps off of old fuel pump
Good Luck
MT
MT
Old 11-01-2006, 03:34 PM
Good Luck
MT
Hehe. Oops.
Believe me though, I squeezed it plenty. That was the first thing I did. I squeezed it every which way until I couldn't squeeze anymore. I shoved things in there to pry both sides out, and then I went back to asqueezin'.
But as you see, I'm pretty dopey.
Old 11-01-2006, 04:13 PM
alblogg's Avatar
alblogg alblogg is offline
Yepand if I remember right that is the one that is a bit@@ to get back on also because you have to push it so hard to get it to go on.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 11-01-2006, 04:38 PM
MT-2500's Avatar
AF - Advisor
Hehe. Oops.
I know they are a pain.
And they are using more and more of them on newer stuff.
They have even got one that is harder than that one to unsnap.
Rear wheel drives I remove the drive shaft and lower the tank a little for more room to work at getting the dang things off and on.
I had a 00 silverado today with about 4-5 of them on the tank and charcoal canister .
MT
