Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-31-2006, 10:18 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Oversized Valve guides??? HELP
Okay so I decided I am going to go with oversized valves and get a 5 angle valve job done. But, while I was looking at valve guides on slowboyracing.com I found bronze valve guides. The problem is that they offer a standard size and 1mm over. Do I need the oversized guides with oversized valves?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-01-2006, 02:41 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Oversized Valve guides??? HELP
Yes, but may I ask why are you going with oversized valves? Are you going to need them? With OS valves, the valves and pistons run a closer tolerance then with stockers, and that means that you have that much less space to mess up with on timing before something bends. Unless you ABSOLUTLEY need them, I would just stick with SS stock valves.
95 Talon TSI AWD
97 Eclipse GST
Old 11-02-2006, 10:10 PM
NateS's Avatar
Yeah, thanks. I have decided to go with stainless steel valves and keep the stock size. BTW the valves I want come with a nitrided option. The option does not cost more but, what is nitrided? Anything special? Heres the link http://www.slowboyracing.com/more.php?id=1129&
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 11-03-2006, 02:10 AM
It's a hardening treatment for the valves.
95 Talon TSI AWD
97 Eclipse GST
Old 11-04-2006, 11:02 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
its like heat treatment for exhaust manifold bolts. damn exhaust manifold bolts..
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
