Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 10-31-2006, 10:08 PM
js39 js39 is offline
Transmission Maintenance
What periodic maintenance needed to keep the transmission fully tuned. A 2000 silhouette with Pressure Control solenoid just recently replaced with some tranny fluid change. But it doesn’t have the full fluid flush and filter change yet. I heard something about sometimes there is some gunk/sludge buildup cause tranny to go sluggish.
Old 11-01-2006, 06:39 AM
maxwedge maxwedge is offline
A990 racer
Re: Transmission Maintenance
Stay away from these full flush machine techniques, was the fluid clean and not burnt before the pcs repair, if so you are good, maybe add a bottle of Lubegard red.
Old 11-01-2006, 09:25 PM
Thanks for the reply. Yes, transmission fluid was good and never burnt. What is a Lubegard? MAF, Cylinder Misfire and lagging PCS codes were set. MAF was cleaned; STP GAS Treatment was added to the fuel (returned excellent gas mileage after the PCS replacement) for misfire remedy. Axle seal also replaced. Now I an not sure a remedy for slow pickup (no slipping observed) from a full stop could either be fix by a transmission filter replacement (not advised by dealer) or start by replacing sparkplugs (still have original, van just crossed 100k), air filter, fuel filter, and PCV valve.
