Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-31-2006, 07:34 PM
agustincorrea agustincorrea is offline
Upper Strut mount I35 02
Hi, All
Have anyone changed the upper strut on any I35 2002. I have a bad noise and it happens when i pass over a road bump. Shock absorder is in excellent condition and tierod ends in & out and Ball joints are new.
Does someone has removed the Shock absorder before. Do you need to compress the spring in order to replaced the upper plate with bushing?
Thanks,
Augie
[email protected]
Old 10-31-2006, 09:53 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Upper Strut mount I35 02
you don't need to compress the spring to get the strut assembly out of the car, but you do have to compress it to take the top plate off or else the spring will shoot off. your best bet is to put the spring compressors on with the car on the ground, so the weight of the car compresses the spring for you, then jack it up and go to work.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-01-2006, 12:08 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Typical Noisemakers : Loose shock shaft end nut, or broken/loose strut cap(or valves inside), antiroll bar. The bearing is reliability is 300x to shocks, but of course anythin may break... U will get structure pics by seeking via links below.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 11-01-2006, 03:52 PM
Does the upper plate get loose when the strut goes down?
Do i need to change the bearing? It sound like a piece of can bouncing in the upper part of the suspension and does it mostly whe you pass a speed bump at lower speed.
I already rented the Spring compressors at Autozone here in Tucson AZ and will performe the surgury tonight in my garage.
Thanks Gents!
Augie
Old 11-01-2006, 05:43 PM
BP2K2Max's Avatar
the upper plate only comes loose when you undo the center bolt.
i had to change my strut bearing but it was because when i'd turn the steering wheel it made a noise like "crink crink". i don't believe it would cause the noise your experiencing.
BP's Rides;
Old 11-02-2006, 09:26 AM
Changed both sides but seems like the Shock absorber is the problem.
Will try to re-adjust the shock absober nut but its most likely that i need new shock .
Does someone knows where I can buy them at a reasonable price?
