Old 10-31-2006, 05:00 PM
dazada's Avatar
dazada dazada is offline
Send a message via Yahoo to dazada
A Chevy newb with some questions.
I'm really considering a '96 Impala SS, but first I have some questions.
(This probably should have went into the Impala forum, but I figured there would be more engine-related knowledge floating around here, opposed to all the idiotic "rollin on 24's" crap.)
1. What is the difference between the LS1 and the LT1?
2. Can LS1 parts fit on the LT1?
3. While browsing through a Summit catalog, I saw alot of parts that said they were compatible with the Camaro/Firebird LT1. Would these parts (aside from the obvious like exhaust and intakes) fit on the Impala's LT1?
Thanks everybody, and remember, I'M NEW....so go easy on me.
Old 10-31-2006, 05:46 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: A Chevy newb with some questions.
LS1 parts will not fit on an LT1. The LT1's in the impala are the same as the f-bodys except for cylinder heads, and exhaust (i think).
LT1 is a gen 2 block with reverse flow cooling that was used from 92-97.
LS1 is a gen 3 block that shares nothing with the LT1 execpt its still a push rod v8. this engine was used from 97 to 04.
if you wanna know anything more specific just ask
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-31-2006, 05:48 PM
stieh2000's Avatar
stieh2000 stieh2000 is offline
You made the right choice in comming here with the questions. They will be promtly awnsered at least 3 times each in more detain than what you need, all with entertaining jokes and off topic ramblings.
1) The LS1 is aluminum (vs. the iron block LT1) and makes more power, especially at high rpms.
2) I think a few basic parts might be compatable, but for the most part no.
3) Engine parts are engine parts, be it for an Impalla, Camaro, Trans Am, or Vette, or whatever else they put the LT1s into. If you have a specific part in question, just ask and we can help.
Those are the basics, hope it was helpful.
Old 10-31-2006, 06:43 PM
dazada's Avatar
Let's say for instance I want these Edelbrock heads,
http://store.summitracing.com/partde...5&autoview=sku
This Edelbrock cam set,
and this Holley throttle body.
Do you think they would fit? Also, does anyone know if an ECU power-programmer for a Camaro/Firebird LT1 would work with the Impala?
Thanks for answering my questions so quickly! You guys have been a big help!
We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything with nothing.
Old 10-31-2006, 06:50 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Bah!
go turbo...
http://www.turbochargedpower.com/Imp...SS%2094-96.htm
Seatbelts Saved My Life
Old 10-31-2006, 06:55 PM
dazada's Avatar
Originally Posted by 2.2 Straight six
Even though that probably puts out a rediculous amount of horsepower, I'm 95% positive I won't be FI'ing the SS (while the other 5% of me wants a low-boost supercharger). I want to keep the Impala around for a long time. I've wanted a '96 Impala SS for a LONG TIME, and now I've finally gotten a job to where I can afford one (and the gas for one).
Since I can't quite afford the fully restored 1970 Chevelle SS 454, I'll gladly take the Impala as an alternative.
Old 10-31-2006, 06:59 PM
with twin 67mm turbo it'll give you over 1,000bhp at the wheels.
Old 10-31-2006, 07:01 PM
dazada's Avatar
I'd be happy with 300 at the wheels. All I want is a mildly-modded SS. Nothing insane.
Old 10-31-2006, 07:24 PM
ZL1power69's Avatar
GM S-Series Mod
with a few boltons (intake, tb, tb foil, 1LE elbow, headers, high flow cat, catback, underdrive pulleys, PCM tune), you can achieve that goal quite easily. there are also some free mods u can do.
Low 11 sec sleeper
My Cardomain
Old 10-31-2006, 07:31 PM
dazada's Avatar
Do you think Hooker long-tube headers and the Impala Borla exhaust would be too loud (the Borla exhaust has two mufflers and two resonators)?
If you think it would be a better idea to go with the shorties, what brand would you reconmmend? If I go with the shorty setup, I'd be pretty set on the Magnaflow high-flow cats and the Borla exhaust system.
Old 10-31-2006, 08:13 PM
ZL1power69's Avatar
GM S-Series Mod
long tubes are usually net you more low end torque. i dont think the headers with borla exhaust would be considered too loud. the this about borla is that the system should be adjustable with plates on the muffler. one of the plates allows you to totally bypass the muffler, which would make it a more radical sound. the cheapest header would be the pacesetter long tubes. the borla system will not be cheap because it is adjustable and it is totally made of stainless steal. magnaflow or flowmaster are good also.
Low 11 sec sleeper
My Cardomain
Old 10-31-2006, 08:30 PM
dazada's Avatar
Yeah, at Summit.com, the Borla system is close to $1000. But seeing as how I plan on keeping the car for a long time, It'll be a grand well invested.
Well it turns out that those Hooker long-tubes are actually shorties. My only option for long-tubes are these Heddman hedders.
Could anybody tell me if they would mate-up directly to the factory exhaust (by bypassing the cats altogether)?
Old 10-31-2006, 08:32 PM
ZL1power69's Avatar
GM S-Series Mod
most headers will run around there too but the cheapest are the pacesetter Long Tubes.
Low 11 sec sleeper
My Cardomain
Old 10-31-2006, 08:41 PM
dazada's Avatar
Pacesetter only has headers available for the Camaro/Firebird LT1. Even though it's the same engine, the Impala's exhaust might run differently. Even though the Heddman hedders are $450/pair, it would be a worthy investment.
Old 10-31-2006, 09:33 PM
ZL1power69's Avatar
GM S-Series Mod
definately. make sure they are emissions legal
Low 11 sec sleeper
My Cardomain
