Old 10-31-2006, 03:37 PM
wareagletsf wareagletsf is offline
abs, brake and airbag lights flash intermintly
I have a 1995 chevy astro van with 155000 miles and have a interesting problem, the abs, brake and airbag lights flash some of the time when going over a bump or under accelration/deccelration, and the air bag light will stay on I have had it in a shop and they can find nothing wrong with any system.
also the rear wiper and rear window release will not work (( if I jump from the red wire to a ground I can get the hatch open )) the hot when on wire is dead to the radio
any ideas?
Old 10-31-2006, 04:43 PM
old_master's Avatar
Advisor/Moderator
Re: abs, brake and airbag lights flash intermintly
Remove the fuse, look closely and make sure the fusable element is intact. Make sure the terminals are clean on the fuse and in the fuse panel, and that the connection between the two is tight. Reinstall the fuse. Use this same procedure, one at a time, for each fuse, and you just might find your problems, (more than likely the two are unrelated to each other).
