Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 10-31-2006, 02:35 PM
zerocrxsi zerocrxsi is offline
88 crx si w/b16. having problems. PLEASE HELP!
Hello AF, im having issues with my car...
I bought the car running like sh*t because it wasnt wired right. Got it rewired and put in missing 02 censor. im having two problems i can resolve..
1. Vtec not engaging. trowing code 22 (vtec pressure switch). i got a new vtec solenoid and that didnt work. My guess is wiring or ecu. I dont have ohm tester, only volt tester. How do i test wiring and ecu?
2. Fuel seems to cut off after 7k rpm. car runs kind-of-strong (no vtec) until a little past 7k and then engine feels like it revs back, like the fuel cuts off. I was told it was cus i was missing 02, but i put one in and does the same. They told me it could be weak fuel pump but car runs fine until 7k rpm.
im using PR3 ecu and have yet to do a compression test, but car seems to run fine (a lil slugish) I dont have a lot of tools or money....Any ideas?
Old 11-01-2006, 06:25 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: 88 crx si w/b16. having problems. PLEASE HELP!
not sure for two, but one sounds like you need more oil. vtec wont engage unless the oil level is high enough.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-01-2006, 10:02 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
why did you replace the solenoid and not the pressure switch? are you still throwing any codes? do a compression check. sounds like my crx when i first bought it. then i found out #3 cylinder was shot.
-tony-
2000 honda s2000
Old 11-01-2006, 01:54 PM
Engine has oil enough oil, i just changed it. AS for the pressure switch, i changed the whole solenoid unit, including the pressure switch (it should be the bottom plug-in, right?)
Old 11-01-2006, 04:35 PM
yeah. hmmmm, are you still throwing codes?
what about a compression test?
-tony-
2000 honda s2000
Old 11-03-2006, 01:07 PM
Yea its still trowing code 22(vtec pressure switch) and as far as copression test, ill get on it this weekend, but one of my friends said he had bad compression, bad rings, and leaking oil and still poped vtec on his b16. I still cant figure out fuel cut of tho. I really need to get this car runing right, as soon as i do im boosting it.....Vtec+Boost= Tha Sex
