Old 10-31-2006, 02:26 PM
5alvarez 5alvarez is offline
Unhappy 97 gmc fuel problem
I have a 97 Gmc safari cargo van does anybody know what could be causing the gas gauge to jump read full when its not. when it does this the van starts to want to shut off when given gas. but idels good when i dont give it gas.after awhile the gas gauge will jump again and read accurate.then the van starts to run good again.Ive changed the fuel filter and im just about to change the fuel pump. please reply if can help. Thank you
Old 11-01-2006, 11:01 AM
joelmc59 joelmc59 is offline
Re: 97 gmc fuel problem
Change out the Fuel Pump assy. This is giving your false readings and needs to be changed. They run about $300 in Autozone. Unfortionatly you will have to drop the fuel tank to change it out.
Old 11-01-2006, 03:06 PM
Hey thanks im gonna try a new pump hopefully thats it .But would that cause the van to turn off when givin gas?Only when the gas gauge starts to act up is when the van wants to shut off.You think maybe the computer is going bad?
Old 11-04-2006, 05:17 PM
old_master's Avatar
Advisor/Moderator
An erratic fuel level sending unit will not cause any driveability problems. The fuel pump however, will certainly give driveability issues if it looses its ground. The fuel level sending unit will indicate "full" if it loses ground. The fuel pump will shut off if it loses its ground. The fuel level sending unit and fuel pump use the same ground. If that ground has a poor connection somewhere, both erratic fuel level indication and driveability issues will be encountered simultaneously. Check all connections before replacing the pump assembly. You may just have a poor connection and not need the module replaced.
Old 11-09-2006, 10:56 PM
Thanks alot thats what the problem was wiring harness runs great now thanks again
