Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-31-2006, 01:22 PM
chrisinidaho chrisinidaho is offline
82 Cutlass Supreme HeadLamps
Thanks In-Advance from Chris in North Idaho all !!
My cutlass lost all headlights last night , there are NO other electrics out.........
Running Lights work !
CAN'T find the fuse/breaker to even START diagnosing...
*Any* help will save me !!
Chris
[email protected]
Old 10-31-2006, 06:49 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 82 Cutlass Supreme HeadLamps
Welcome to AF Chris!
The fuse block is located under the left hand side of the instrument panel.
The fuses are marked on the fuse block as to which circuit it's protecting.
As for the headlight them selves it very well could be the headlight switch that is faulty.
Hope that helps !
1999 Grand Am SS 3.4 OHV
Old 10-31-2006, 07:24 PM
Thanks for the reply !
At least the SUN was out today to work on this.
Traced *everything* until I had the dash all the way out , and found the turn-signal-lever ( which controls high/low beam ) was jammed with *some* debris/dirt/whatever , and was responsible for the power *not* reaching the headlamps , but going THRU the headlamp switch....
All
IS
WELL
(( had a really dark ride home last night ))
maxwedge maxwedge is offline
A990 racer
Chris
[email protected]
No seperate h'lite fuse, there is a circuit breaker in the switch, check your connections at the dimmer switch on the bottom of the column also.
