Old 10-31-2006, 10:02 AM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
Neeed Help Fast Please
alright im doing my plugs and wires. on a 2000 GTP. i couldnt get the wire boot out of the silver cylinder. welll then it broke off inside the silver cylinder. so i just yanked the silver thing off. but theres a spring inside the silver thing. where does that sping go. on top of the plug before the wire? between the block and the plug?, or between the plug and the bottom of the silver cylinder
thanks''
if you live close by give me a call that would be better
630-289-2772 thanks
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit
Old 10-31-2006, 11:04 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Neeed Help Fast Please
The metal shield is a heat shield and anti-static suppressor. The shield removes from the plug boot and the spring is supposed to stay intact. The shield and spring is slid over the plug boot. The spring should be at the bottom of the shield. Then inserted over the spark plug tip/electrode/ceramic intact with wire and then snaps into place.
Timeslip 08/12/06
AF Community Guidelines
