Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 10-31-2006, 09:25 AM
cfthornell cfthornell is offline
Weird Noise in Steering Column
I've noticed, just in the last two or three weeks, a noise in my steering column when I turn left or right. At work, I have to drive up two levels in a parking deck, and when I make those turns, whether it's the right turns going in, or the left turns coming out, it sounds like a wind is whistling through the column. It can't be that, though, as I'm only going about 3 MPH either way. Anyone else heard of this?
Old 10-31-2006, 09:19 PM
Blue Bowtie's Avatar
Registered Offender
Re: Weird Noise in Steering Column
You may be hearing fluid flowing through the assist valving in the steering gearbox, and the noise can be transmitted up the column through the shaft.
Old 11-01-2006, 01:25 PM
amichals amichals is offline
I have that same problem. Do you know if that should be ignored or will it turn into a bigger problem?
Old 11-01-2006, 06:58 PM
paul1965 paul1965 is offline
There's a good chance this could be an intermediate shaft in the column itself that's drying out. There's a TSB out there from GM to address this concern. In most cases, there's a kit available from GM to repack the shaft.
ASE ceritified: Engine Repair, Engine Performance, Brakes, Steering/Suspension.
