Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 10-31-2006, 09:19 AM
mza1979m mza1979m is offline
Valve grinding resources?
Can anyone here please direct me to an informative website/Internet resource that displays information pertaining to valve grinding? I want as much detail about everything there is to know about valve grinding and how to do it.
Thanks in advance.
Old 11-01-2006, 12:18 AM
KimMG KimMG is offline
AF - Advisor
Re: Valve grinding resources?
Check out your local junior college, night school, or vocational school. You maybe able to find a low cost class where you can get hands-on experience. In my opinion and experience, I have found it better to actually demonstrate and let the person I was showing how to grind the valves do the grinding and fitting in the head.
Old 11-01-2006, 08:12 AM
Sorry, perhaps I should have been more specific. I am a college student majoring in Motive Power and I must do a lap prep for "Valve Grind". However, I'm finding it difficult to locate a good online source for my research.
I don't know a whole lot about valve grinding, which is why I need to know everything about it before I begin the actual work on it in class.
Old 11-01-2006, 08:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks in advance.
Your local machine shop that does valve grinding and cylinder head work would be a good source of information.
Also engine or cylinder head rebuilders may help you some.
Good Luck
MT
MT
Old 11-01-2006, 09:02 AM
MT-2500's Avatar
AF - Advisor
Thanks in advance.
When I started out years ago almost ever repair shop had a valve grinding machine and done there own valve grinding.
45 years ago I could grind the valves and do a tun up on a chev 6 cyl before noon.
Now I am luckie if I can even get a tune up before noon.
But any more heads require a lot of machine work with a valve grind job.
Now heads need to be sent out to a machibe shop for head work.
Many needs valve the guides replace and heads checked for cracked and surface checked for warpage and other stuff that only a repier shop can do anymore.
MT
MT
Old 11-01-2006, 11:46 AM
Guys, I'm looking for an ONLINE source of information on how to do a valve grind. This is only a prep for a school project, among 20 other preps. I'm certainly not going to a local machine shop to learn about it because I'm just looking for a step by step guide so I can hand something in to the teacher.
Thanks for trying anyway.
Old 11-01-2006, 11:54 AM
MT-2500's Avatar
AF - Advisor
Well if you want good info on it go to the source.
I dought if you are going to find much online on that subject.
You need to do some legwork on that one.
Good Luck
MT
MT
Old 11-01-2006, 04:23 PM
AF - Advisor
Have you tried the databases the school library subscribes to?
I found this while doing a quick google search
http://64.78.42.182/sweethaven/MechT...Num=4&modNum=4
Old 11-01-2006, 04:50 PM
MT-2500's Avatar
AF - Advisor
Not bad info there KimMG
The old google search may save him some leg work on it.
MT
MT
