Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-31-2006, 08:36 AM
blu88notch's Avatar
blu88notch blu88notch is offline
3s-FE ignition timing
Is the ignition timing in my 89 Camry adjustable?
If so, does anyone have "how to" info on setting it?
I did a search on this and came up with only the stock setting of 10* no other info.
Thanks.
'88 LX notch. -For fun 13.68@ 99.7
'05 4wd Sorento LX. -Baby hauler
'01 Focus -the commuter
Old 10-31-2006, 12:25 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 3s-FE ignition timing
Check the label on the underside of your hood for the procedure for checking the ignition timing.
Normally, you attach a tachometer (remove cap on service connector of distributor for connection, blue wire with green connector) and a timing light (no 1 spark plug wire), start the engine, and then insert a jumper wire (paper clip) between terminals T and E1 on the service connector next to the AFM.
You check the timing at a specific rpm by shining the timing light on the crank pulley and seeing where the timing mark sets with relation to the marks on the scale on the engine.
You adjust the timing if wrong by loosening the hold-down bolt on the distributor and turn the distributor a small amount to correct the timing. If you're careful, you can adjust the timing while the engine is running and check it with the timing light as you make the adjustment.
Tighten the hold-down bolt and remove the jumper.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-01-2006, 07:07 AM
blu88notch's Avatar
Good. I have adjusted the timing many times on my Mustang so know that I should be ok. So when you say "AFM" what is that short form for?
Old 11-01-2006, 10:14 AM
Brian R.'s Avatar
Resident Chemist
Air Flow Meter
