Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-31-2006, 02:38 AM
jjones1193 jjones1193 is offline
1995 Eighty Eight Engine Coolant Temperature
Hello, I was wondering what the normal engine coolant temperature was on my eighty eight. Mine runs around 230 degrees. Seems a little hot to me.
Old 10-31-2006, 06:37 AM
manlystanley manlystanley is offline
Re: 1995 Eighty Eight Engine Coolant Temperature
a little hot to me.
Check on some of the past messages on this forum, but I think (??) that the fans should come on at 212. I think 230 is a bit high as well. My 88 was running hot and I put in a new thermostat.
Best Regards,
Stan
Old 10-31-2006, 10:36 AM
maxwedge maxwedge is online now
A990 racer
Question Re: 1995 Eighty Eight Engine Coolant Temperature
How did you get this temp reading?
Old 01-04-2007, 06:02 PM
Xandermull Xandermull is offline
my 92' olds 88 runs about 150 degrees warm, pretty cold if ya ask me, but the new radiator and seperate trans cooler make a differene, as well as your antifreeze/water mix... i believe at 1995 they shoudl still run 30/70 (AF to water)
If it's runnign hot first i would change coolant, older coolant that ionizes (common in the v6 blocks) will nto cool as efficiently as fresh fluids.
After i would check and ensure that the front of the car has ample breathing into the radiator as flow resitriction will cause problems, also ensure that fans are working properly and that there are not bent fins on the radiator.
After these check out i would target your thermostat as improper function will amek teh car think that it's running too cold and attempt to warm it up by setting the fans in the delay setting, keep em from running. Commonly on interstate travel they go into delay after a long period of use as the radiator will cool efficently enough to not run the fans at high speeds.
Hope this is some help!
Old 01-05-2007, 02:56 PM
Bassasasin Bassasasin is offline
I think the thermostats are opening at 175. It should regulate it to about 190. You have a coolant restriction problem somewhere. Radiator or even the thermostat itself. They are cheap and easy.
Check it out...
Good Luck.
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
