Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 10-31-2006, 01:10 AM
wtf-u-say's Avatar
wtf-u-say wtf-u-say is offline
Question how to pull trouble codes 85 crx si...
I've had this 85 crx si [ew3] for some time now and the PGM-FI light came on. I have read in this forum that the light comes on because of a stored trouble codes. How true is that?? Also what kind of lil upgrades can i do to put a lil more gitty up in performance.
Old 10-31-2006, 03:19 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: how to pull trouble codes 85 crx si...
It is true. You should be able to pull the carpet back from under the passenger seat and look at the ECU. It should light up 1 or more of the four lights. If you get the numbers that the lights are and search for the trouble code post, you should be able to decipher what is wrong.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-31-2006, 10:07 PM
wtf-u-say's Avatar
THank for the info I found it. this car i am working on is totally stock, Except for the cold air intake. Do you think its possible to add a lil more performance to this car with out spending alot of money. Until i get some real money saved up. Thanks again Figori.
P.S I have read alot of your post's. You and that guy Lxndr know alot of stuff. BIG UPS TO BOTH....
Old 11-01-2006, 02:02 AM
wtf-u-say's Avatar
well i found the red lights and they read from left to right 8421, # 4,2 are lit. I found the codes on a thread but the problem is how do i read it. #42 does not apply to 85 and #24 either. The only thing that i could come up with is #2 oxygen sensor"b" defective circuit or unpluged. The other one is #4 ckp sensor defective circuit or unpluged. Does it have to blink or am i doing something wrong. Have patience with the newbie. I realy apreciate it man.
Old 11-01-2006, 07:27 AM
Figori's Avatar
You need to make sure you're looking at the right Engine Code list. Here's the correct list.
By looking at this list, it reads:
8.] 0 4 2 0 ____ High idle speed durring warm-up, continued high idle or hard starting at low temperature
Then you go down to the #8 symptom and you get:
8. Check for a disconnected coolant temperature sensor connector or an open circuit in the coolant temperature sensor wire. Also check for a faulty coolant temperature sensor.
Old 11-01-2006, 06:01 PM
wtf-u-say's Avatar
Ok, I see how it works. Hey thanks for your time and patience figori.
Old 11-02-2006, 09:04 AM
Figori's Avatar
No sweat. I was a n00b once.
Old 11-02-2006, 06:49 PM
wtf-u-say's Avatar
