Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-31-2006, 12:38 AM
morgantj13 morgantj13 is offline
tachometer in 1989 eighty eight
Have any of you guys put a rpm thing in your 88? the reason I want one is because im interested in knowing more than just the speed, I want to know what rpms im running at..
even if you havent done it, do you know if it could be done?
thanks
Old 11-04-2006, 04:28 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: tachometer in 1989 eighty eight
Yes, this is do-able. You would have to splice a wire in from the ICM (I don't know which one though) and run it into the cabin to an aftermarket tach.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 11-06-2006, 04:22 PM
k, thanks but what is the ICM...once I know that, I would be able to do the wiring
Old 11-07-2006, 12:20 AM
Alibi's Avatar
The ICM is the Ignition Control Module, located under the coil pack, near the front of the motor (radiator front). The coil pack is where all the plug wires terminate.
-Eric
Old 12-10-2006, 09:24 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
why do i get the sinking feeling morgant is crying somewhere in a corner with wires in his hands...
You need a particular gauge for this because its a waste sprk system. A regular gauge would have you thinking that you are idle at 1300 rpm, and at the high side you'd be reving at a mighty 8000 rpm... SWEET
Old 12-10-2006, 11:59 PM
no, im pretty sure im not crying with wires in my hands...I just decided to not put in a tach becasue, well, I dont need it. Im now saving up for an srt-4, so putting a tach in my 88 is low on my list...even if i did cut wires and crap, i would know how to put them back together cause Ive been doing electrical stuff for years
