Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 10-30-2006, 11:44 PM
Zuki Zuki is offline
AMC 360 Crankshaft Help
I just bought a 360 engine and found out it doesn't have the centering flange on the rear of the crankshaft. So it must be from a 1970 engine , can I use it with a newer flywheel or do I need to change cranks?? Thanks for any help.
Old 10-31-2006, 09:21 PM
bdiamond69 bdiamond69 is offline
Re: AMC 360 Crankshaft Help
all i run is amc's and as far as i know you should be able to use you newer stuff. Amc v8s are externally balanced the flywheel has to be balanced to the rotating Assembly.
89 jeep wrangler with a 360 amc v8 40 over
msd ignition system from box to wires
edelbrock performer intake, cam
holly fuel inj
k&n air filter
tubro 400 trany with shift kit
dana 44 axles 4.56 gears
all 4 wheel power disc brakes
6 1/2 inchs of suspension lift
rci racing seats
simpson 5 point harness
griffin aluminum radiator
REAL JEEPS ARE BUILT NOT BOUGHT
LIFT IT --- FAT CHICKS CAN'T JUMP
Old 11-30-2006, 09:51 AM
jeepmeister jeepmeister is offline
I have found the crankshafts without the centering flange are common with standard transmissions with the flywheel, which is what you may have. The 360 engine was not used until late 1971.
