Old 10-30-2006, 10:40 PM
PlayStation3 PlayStation3 is offline
underpowering question
hi i am planing to run an MTX Thunder564 (70 watt X 4 @ 4ohm) to power my alpine type x compenot speaker but there rms is 75 i have heard that the MTX Thunder564 is underrated so would that still be underpowering the speakers?
Old 10-30-2006, 10:48 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: underpowering question
"underpowering" is only when you don't have enough power to satisfy your listening needs (meaning you have to clip the amp in order to get it to the spl you want). It all depends on you and your needs, not the speaker's power rating.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-31-2006, 12:16 AM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
When someone says that the amp is underrated, they mean that it's actually more powerful than what it's rated at. Hence the factory is "underrating the speaker." Should match up perfectly but because most companies test at 14.4 volts you might get a little less than what they rate it at. Either way, 70 watts rms at 4 speakers should sound pretty good. My Infinity Reference 4x6 plate's sound fucking amazing in my truck, and they're only getting about 25 watts from my head unit which is rated at 31 rms(Panasonic Digital 70X4). I'll be happy as hell when I match up Infinity's 6 channel amp to them with a pair of components.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 10-31-2006, 11:51 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Shit you could put 35 watts from an amp and they can sound good, more power means you can tune it to prevent clipping at higher volume levels. You dont ever have to match power ratings from speakers/subs to amps, besides not every sub will come of the line exactly the same, same thing is true for amps.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 11-01-2006, 09:31 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
amp quality, as far as variances in specs from unit to unit, are easier to control than speaker quality - or at least that's typically what you see.
Old 11-01-2006, 03:03 PM
ok so the 5 watt difference is not going to effect it .
Old 11-02-2006, 09:44 AM
Audio Guy
no
it's not uncommon for guys into sound quality to put 150-200% of the speakers rated power into them.
Old 11-02-2006, 07:02 PM
v10_viper's Avatar
Originally Posted by PaulD
no
Exactly, I was told that my Infinity's could probably handle 75 watts continuously without being damaged. I don't feel like testing this though. I don't feel it's need either, as seeing what 30rms/70 peak rating does to them I can't wait to see what 50 rms/110 peak does to them. For being as tiny a speaker as they are they have AMAZING excursion.
Old 11-02-2006, 10:10 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
no
Just don't be like me and have 4kw on tap for a pair of towers in a dang dorm room...
Old 11-02-2006, 11:15 PM
v10_viper's Avatar
