Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-30-2006, 09:24 PM
Phil0968 Phil0968 is offline
Send a message via AIM to Phil0968
Aftermarket Stereo
What are the speaker sizes for a 1997 Nissan Maxima SE, front door speakers, tweeters and rear? Also What is the best method to install and after market deck into the vehicle abt info would be greatly appreciated.
Old 11-02-2006, 10:18 PM
Re: Aftermarket Stereo
Has anyone put an aftermarket stereo in their Max??? Cmon help me out here
Old 11-03-2006, 02:12 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
with bose they're 6-3/4" door speakers front and rear. i don't know what size the tweeters are.
to remove the deck you have to take the screw out of your ashtray, and then pull up all the plastic starting from the shifter all the way up to the climate control. once it's apart undo the 4 screws that hold the stereo to the car. take that bracket out and remove the stereo from it.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-07-2006, 09:46 AM
How do u remove the speakers, I was trying to pop out the speaker covers but it appears that they are screwed in, but im having issues getting to the screws, it appears on the front door speakers u have to remove the door panel, but how do you get to the back speakers, do you have to remove the carpet covering the back deck?
Old 11-12-2006, 08:29 PM
Anyone? Removal of rear deck speakers? any help would bemuch appreciated
Old 04-02-2007, 04:41 AM
krutoi krutoi is offline
to remove the front speakers, you must take off the door panel. pop out door handle cup. around the lever itself. then carefully pop the door off from the edges.
to take out the back speakers you must take out the lower part of the back seat by pulling 2 levers or unscrewing 2 screws on the bottom front of the seat. then unscrew 2 scews on the bottom of the top part of the seat. slide the seat up and off. then take out the rear deck and get to the speakers. they are both same size. 6 1/2
or if your in the georiga area, let me know and i can do it for you.
