| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
4R70w Won't Shift out of 2nd
This is a 96 F150, 4wd, auto, 128k mi. that has been just falling apart in the driveway on me. I bought it with 108 k mi. about 2yrs. ago. This time it seems it does NOT want to shift out of 2nd gear. Going 50 mph it revs about 3k+ rpms. Sometimes going from 1st to 2nd seems to be a challenge.
I checked the trans fluid, added about 3/4 quart to top it off. Nothing on driveway, so where is it going? According to the door sticker it has Trans code: U, I guess that it a 4R70w trans. Does it have a vacuum, modulator? If so where the hey is it? Looked high/low...nothing. No drain plug on it to drain the trans, WTF. I have no idea if the previous owner changed the fluid but I know he was big on Ford service. I was hoping this might be something I could do myself. I really like this truck but it seems it is turning into a money pit. I will be away for about a week but any thoughts or ideas on what I could check when I get back would certainly be appreciated. Oh, the Check Engine lite is NOT on but cleared the codes by pulling the PCM fuse yesterday, thinking maybe something there was causing it to misbehave (trying to be nice). Today I took it to get the codes read - printout said No Faults detected but DTC Pending codes =P1401. I believe that is EGR Sensor Circuit, High Voltage but I don't know what to check on that and don't think that would have anything to do with a shifting problem? Would it? Thanks Gumby_CT
1998 Chevy Tracker 4dr, 4wd, auto, 1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi. My other car...in need of repair it won't start any longer 1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav) |
Re: 4R70w Won't Shift out of 2nd
A bad speed sensor or mlps will cause the tranny to go into fault mode witch will cause it to stay in second gear. you will have to run the tranny cades.
Where do I find the mlps and speed sensor? What do I have to do to check them? Thanks
its obd2 you just have to have the right code reader. you might try a tranny shop or the dealer
OK, the code still reads P1401. They didn't know where the mlps or speed sensor were either.
