Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-30-2006, 06:43 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
16g install gone Wrong.
I started a thread a few weeks back when i got my 16g in the mail. Anyway this past weekend i finally had everything to install. Removing the old t-25 was not bad at all but installing the new oil lines for the 16g was a royal pain. I was supposed to leave the existing lower half of the oil line intact and connect my braided line to it. Im not to proficient in fittings but it did not fit right. I had no clue what to get to make it work. After debating a few hours i went out and bought some sort of fitting to go into the block to get the oil and plugged the lower oil line.
Oil line done. Well what else can go wrong...... Then i get to the intercooler piping off the j-pipe. Well after hacking my stock one on there, reconnecting a few things i was ready for a test drive. Took the car out and now it wont go past 10psi. I adjust my mbc and still wont past 10psi but it has a spike to 15 when it starts to boost. Ok.. not so bad. Prob a boost leak. I figured it would get me back home (installed by my uncle's house 35 miles away). Well i drove about 2 miles when i completly loose boost after 5 psi. After pulling over. The Rubber crap intercooler pipe had a nice sized cut in it. I still drove it home not boosting at all.
The only positive is that im not going to spend money buying a ic pipe from the stock ic to the 16g. Excuse for a front mount. . Any suggestions. I cant make my own piping. And Exhaust shops around here only press bend. So it is going to have to be a full kit.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 10-30-2006, 07:19 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 16g install gone Wrong.
You blocked off the lower oil line? What the hell were you thinking? Better throw a new turbo on that shopping list of yours.
If I had to buy a FMIC kit it would be the SBR one.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-30-2006, 07:34 PM
Maybe i Didnt specify. I Blocked off the lower one and used a line off the block to supply the oil to the turbo.
Old 10-30-2006, 07:51 PM
Thor06's Avatar
Jizzed In My Pants
That is still unclear, is there a supply and a return line coming off the turbo? If not you better get one and hope you didnt fuck it up.
Old 10-30-2006, 09:22 PM
www.vfaq.com - turbo- 16install in a 2g about 3/4 the way down your going to see "HAVE PURCHASED THE 94' GSX OIL FEED". Just read that little piece.
Old 10-30-2006, 09:38 PM
Thor06's Avatar
Jizzed In My Pants
Do you or do you not have both a oil feed and a oil return line coming off the turbo? Your desciption is vague as hell an that link does nothing to answer my question. From your first couple posts I get the impression you are running only and oil feed line and you plugged the oil return hole on the bottom of the turbo. If you infact did this, kiss that turbo good bye.
Old 10-30-2006, 10:25 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
ebay core and 3 u bends from summit all you need to do is cut the pipe get some clamps and your good to go
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 10-30-2006, 10:27 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
from what i understand. he block off the original oil line and taped the block for another one????
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 10-31-2006, 12:13 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
you're not getting enough oil pressure if you're sending the oil from the head. Thats where people tap for a BB turbos. Stop driving the car and try to find a local DSM'er who can help.
now - 2000 civic
soon - 2002 is300
Old 10-31-2006, 12:34 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Did you have any other problems while installing it? Ive been reading up on it as much as possible since ill be installing the evo3 in my gsx once spring rolls around. If you had any pointers or somthing that you found to make the installation easier please direct them my way.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-31-2006, 07:33 AM
Im in NYC. I know noone around here. Why does everyone say i can tap into the head for sufficient oil flow for a 16g. Thor do not worry. i Have an oil feed and drain.
Old 10-31-2006, 11:11 AM
who is everyone? Tap it from the filter. If you have an SS feed line it's very easy.
Post on tuners in the local forum and see if someone can help. NYC has a good dsm community.
now - 2000 civic
soon - 2002 is300
Old 10-31-2006, 11:18 AM
blk_srt's Avatar
Oil from the head will work fine, it has the same pressure as anywhere else. Thats where 1gs stock get oil for the 14b
Mods:
Old 10-31-2006, 12:26 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Oil pressure is bad for turbos... Those first time turbo installs are fun arn't they? Next time just buy the right kind of fittings. 18in 3/8in to banjo fitting feed line for the head/turbo. Or 28in 3/8in to banjo fitting line for 2g filter housing to turbo..
Check the accuator arm, might be stuck.. Good luck..
DSM geek
Old 10-31-2006, 12:36 PM
Thanks for the info. But how do check the actuator arm?
